SPS
Moderator
Ok guys so as far as GPU OC'ing is concerned I'm a bit of a noob and I'd like a bit of help regarding that and MSI Afterburner.
Now my bro has had a MSI GTX580 TFII for a while and during this period it has been unstable.
None of these fixed the problem so I thought that the factory OC may have been unstable. After Googling around, it looks like others have also had an issue with this card in high demanding games. So I ran OCCT and sure enough the drivers crashed out and the PC BSOD.
I downloaded MSI Afterburner (first time user) and set the core clock to stock 580, 772. I ran OCCT again and it worked fine, nice and stable. So I told AB to set this underclock at start and we shut the PC down. We went out and came back to test this in games.
We fired up a game and the rendering was taking forever with so much lag! It was not long until it BSOD.
I believe the card is no longer under warranty (so my bro says).
Is there any way we can remedy this or is the card knackered?
I thought the underclock would have worked, am I using AB wrong, is there some configs kicking about that should be changed?
I appreciate any suggestions.
EDIT:
PC Specs :
MSI GTX580 TFII 1.5GB
MSI GD65-Z77
2500k (currently at stock)
HX850w
8GB Mushkin Silverline
1TB WD Black
The card is currently at 772 core @ 1.038v, everything is at stock.
- At first we thought it was the drivers so we tried various releases and did a full Windows reinstall.
- Secondly we swapped out mobos.
- Then we changed PSUs.
EDIT:
PC Specs :
MSI GD65-Z77
HX850w
1TB WD Black
