Moving files from R.A.I.D drives.
Terrifictez85
Hey, currently looking at buying a 2tb hdd and moving my things across. the only issue is that my 2x320gb hdd's are in raid 0. All of my games and music is on the array. How would i go about moving it across to the 2tb hdd? Don't fancy re-installing all of my steam games.
Any words of advice?
Acronis true image, clone it all over in one fail swoop. I copied a bunch-o-stuff from one brand SSD to another no hiccups or re-activation required.
should be okay to come OFF that raid array, it's going back onto it that I would suggest would cause issues with drivers.
Worst case scenario is it doesn't work and you still have your raid array working so you can just try something else.
If you don't want to re-install etc, just use Acronis :) works a treat
