More cooling questions! FFS!
name='llwyd' said:
If youre looking for compactness and low temperatures try looking into Peltier / Tec cooling. You can use it in conjunction with your watercooling but would need another small PSU - like the FSP booster
Could be a winning idea - not much cash involved either :)
name='XMS' said:
I was in the same boat as you a few months back with regard to insulating. It may sound daunting but really it isn't.
I've been waiting to see some pics of your pelt in your project (unless you added some and I missed them). Any chance?
name='Ham' said:
It would cost more to buy a pre-built unit and mod it than to build one from scratch here frag. Thoughs things run about £500.
My costs for my SS, inc tools (even the essential ones i don't have yet) is running up on £400. A chiller would be even cheaper as theres no flexline and the evaps can just be coils.
You will need insulation as the temps are below the temp of the room you are in, regaurdless of the sub-zero soultion you chose.
Johann is very reputabile(sp?), and ive not delt with Grey Mole but his reputaion speaks for itself. Both these would provide the best solution if you want it asap. If u were to wait for me id encorperate a iwaki or similar pump and the evap would be a rad/rez in one. I'd happily insulate some tubing with it. The aformentioned guys would also do that i expect. Youd then have to worry about the mobo and block itself.
Who/where are these people? I've decided I want sub zero and no longer have issues with insulation etc!
