Moderator Review: Dell 2405 FPW 24" Widescreen TFT **56k**
Status
Not open for further replies.
It is a bit bazaar mate
CSS has a real "chunnky" feel to it at 1920 x 1200 - kinda weird - all the writing is mahoosive. But it seems I fare better at 1920 x 1200 than 1680 x 1050 so me likes it :) It does run at over 100FPS constant tho :)
Quake needs to be turned down to 2x AA Ultra Quality (with the Dual Core patch on as well) to run smooth but that stays at a constant 60FPS at the highest res so thats ok.
COD 2 can be run at 1920 x 1200 @ 4x AA (all highest details) and keeps just above 30FPS which is ok as its aint as fast paces as Q4, but has more going on on screen.
F.E.A.R can be played at 1920 x 1200 at 2x AA and looks nice but I had to get a higher OC on the video card to do that :)
Anyhoo - gaming at that res looks really awesome and although takes a bit of geting used to: its pretty nice :)
Do you actually get more visible area in all of those games, or do you see the same as what you'd normally see on the screen - just stretched a bit?
you see more. jim if u remember i gave u a link a while back that showed a screenshot on dust1, and you can see more around you definately.
No ghosting with the monitor mate
I'll flesh out the review if I can stop playing on this XBox 360 :p
And yeah Frag - its lush fo' sho' :)
Status
