mobo/psu question
pobolycwm
do the newer 24 pin mobos need all 24 pins or can you just plug the 20 pin connector in like you could in the earlier ones
thanks
I think it was mentioned some time ago that in such a case best option is to use 20 pin to 24 pin adaptor...
