Mobo in box?
Socks
Just a quicky, im going to setup my comp in the mobo box (case not ready yet), was just wondering if i need to put anything under the mobo so its not touching the cardboard and theres some airflow or is it ok just leaving it lying flat inside the box?
I wont be overclocking if that helps. ;)
cheers guys
put it on the shiney outside surface of the box so theres better airflow
without overclocking you will be fine, maybe balance a 120mm over the memory and NB
Cheers llwyd.
Those clips you got me, well, wcuk sent out those ones and they arrived today, Still no cpu though :eyes:./ lmfao
