ML140 Controller
Is your motherboard fan control set to voltage or pwm? Also, check your motherboard manual as some fan headers are not true pwm, you want pinouts that say 12v, ground, rpm and speed control. If any of the pinouts are ground, power, rpm and reserved then even though it's a four pin header it's not pwm.
