Dawelio
Active member
Hey guys!
First off, regarding a budget, I will simply just say this, which more or less will be quite complicated and difficult, as low as possible.
Since I have no other directions to give you, I'll leave you bit free regarding this.
This tiny PC should basically just be connected to my TV for movie streaming, youtube and internet browsing in general.
And I'd like to use my old current PCs parts for this one.
I'd also like this PC to be have a black and blue color theme/scheme.
The case(s) I'm thinking of are Corsair Graphite 380T or Corsair Obsidian 250D.
(It's leaning a lot to the 380T)
The parts of my current system are the following:
- Intel i7 2600K 3.4GHz LGA1155 with Corsair H100i
- ASUS Sabertooh P67 (won't use)
- Sapphire Radeon HD 6950 2GB
- Corsair Vengeance 16GB 1600MHz ( 4x4GB )
- Samsung Pro 256GB SSD
- Corsair Force Series 3 180GB SSD
- Silver Power 850W
I will get the small Silverstone Strider Gold Series for this one and the shorter cables with it.
And a new motherboard.
Questions:
1. How big would you people recommend the PSU to be?
2. Which kind of mini-ITX motherboard would you people recommend, that can support my current i7 2600K? (Preferably ASUS and a black/blue colored one)
3. Would a single BitFenix Spectre Pro 200mm Blue LED intake fan in the front, be enough on/in this/these case(s), with rubber mounts?
4. Should I have the back 120mm fan as an exhaust or intake (with fan filter if intake)?
5. Is it a good thing to have the H100i in Pull configuration, to exhaust the heat from inside the case?
6. Me and a mate, will mostly use this one for watching movies at and sometimes want to keep the loudness down... so what I'm wondering, IF it could be possible to perhaps have 2 different wireless headsets connected to the PC at the same time?, to play up the same thing (sounds from a movie or so), in 2 different headsets?...
This is probably the dumbest question ever, but I still want to ask it.
(Hope you guys understand this question as it's kind hard to explain what I mean/looking for)
I hope that this is better for you guys, quite a lot of question marks, but I'm not very good when it comes to parts and components. I just know the basic in how to build one, since I've built my current one.
So I hope this is alright.
Thank you!,
Chrazey
- Silver Power 850W
Questions:
Thank you!,
Chrazey
