mini ITX PC build ideas
Thommo
Hi all,
Ok, so, back into PC building after a few years and how things have changed! My last rig was an AMD Athlon FX-60 with a Radeon X1900XTX - looks positively doddering considering you could build a faster rig for probably a quarter of what that cost me.
I have early stage plans to build a SFF PC for the GF's birthday. Ideally I want to keep it as small as possible and base it around a Zotac H55 Wifi motherboard. I am really here to get some ideas about cases, power consumption and cooling as the thing needs to be small, quiet and stylish, yet have the graphical oomph to drive a 24inch monitor (my cast-off) at native resolution through DVI.
I like the looks of the Nexus Psile case, and like that it comes with a DVD writer as an optical drive is a must.
The full specs are as follows:
Mobo: Zotac H55-ITX-A-E Wifi (Wifi is vital and it would be good to be integrated into the board)
CPU: Core i3 540 or similar (I know Ion boards are available cheaper but it needs to run pretty snappily as if I build a PC she deems to be duff I'll be in for some eye rolling :-)
RAM: 4GB Generic. She's not going to be gaming, OCing or anything more stressful than Skype or watching DVDs. Though Mushkin is the flavour of the month around here, isn't it? I'd spend a bit extra on the RAM if anyone thought that it would be worth it.
SSD: 64GB Crucial. I want to try a SSD in preparation for my own build. Plus it needs to be quick (see CPU above!) 64GB might not sound like a lot, but she'll really only need 20 for Windows 7 plus a few GB for iTunes and e-mails etc. Anything else can go on a USB external drive if she needs it later.
Case: Nexus Psile. Like I said, I am attracted to this case, however it is relatively pricey. Can anyone suggest a similarly stylish (a lot of these cases look fairly industrial!) m-ITX case with room for an optical drive?
Cooling: Passive? I suppose it depends on the case, however if possible I would like to passively cool the CPU - or fit as big a heatsink as I can in order to cut down on noise.
Power supply: No idea. I don't know how much power I'll need to run this lot without overly stressing it. I think 120W should do it. I have no aversion to using an external power brick and a pico PSU; if anyone has any experience with these I'd like to hear from you.
GPU: Onboard
. Looking at using the onboard graphics capability. If anyone thinks that this would be sluggish running a 24inch at 1920 x 1200 and a dedicated card would help, again please give me a heads up. Something with a passive heatskink for preference.
Any ideas or suggestions gratefully received!
Thommo
i understand, i was from the same period, then i dropped out for a while, see my sig, i have a athlon 64 system too still, and i love it, its brilliant
but on topic, that spec looks fair for the price, id maybe sugest a lian li case instead, but ...
otherwise, that should be alrite
maybe a storage drive, proper HDD, like 320 gig, they should be reasonably cheap now?
just a thought
ionicle,
I like Lian Li cases too - my first PC was built in one (now we're going back to an AMD Athlon 3000+ Barton, IIRC!) but they look a bit too big and angular. What she really wants is a nettop, but I've tried to explain that the monitor will be a hassle for an off the shelf nettop to handle. Ideally, I suppose I would like to build the PC equivalent of a Mac Mini (don't worry, I know I won't get it that small!) and for about 10-15% less than they go for, so budget is probably in the region of £500.
Not a bad idea re the storage drive; it had occurred to me, but it's just something else to stuff into the case that she honestly probably won't use. Web browsing, Skype and some DVDs will pretty much cover it. No real need for storage other than some space to synch iTunes.
Cheers,
Thommo
im sure ive seen a review for a mini lian li case, it was ...a bit bigger than a mac mini, but not much, maybe three times the height, but not much more...
worth looking into ...cant remember what its name was though
it was reviewed on this site though i do believe
