Brwmogazos said:for an intel rig ras to cas is very important.
its not only the timings (the obvious 4 ) but others that affect the mem performance as well.
the best timings to go for an intel rig would be 2 2 2 5 which is what my bh 5 can do as well as some rare ch 5 modules.
then 2.5 2 2 5(or 6) would still be fast even though cas latency is set to 2.5 from 2...ras to cas remains @ 2 though.
so yeah 2 3 3 6 would be still fast if you got a high fsb of 250+mhz
ocz is coming with some new EB 3700 modules that can do 533mhz iirc @ 2.5 2 2 5...
i think i may for these sticks myself...and have some fun with my rigs...
name='Warlord Shigs' said:any chance u sellin that ram u got now mate, if not wat otha am would u recommend? as im plannin 2 get sum asap. i kno bh-5 is very hard 2 find now. but i want the nest overclocks with tight timings
Brwmogazos said:not at the moment buddy....
maybe if the ocz 3700 EB comes out but still not sure...its very hard to find some good clocking bh 5 sticks...
name='aXeR' said:I always thought the P4 needed better latency ?
for 1:1 clocking then the 4200 EL is great as far as i know from OCZ...name='Warlord Shigs' said:np so wat ram would u recommend 2 me mate. i want tight timings with high overclockin.
Brwmogazos said:for 1:1 clocking then the 4200 EL is great as far as i know from OCZ...
push some extra volts and it will fly.
i have faith on the new 3700EB modules though from ocz...the kick some serious £$*% man with their timings and high fsbs![]()
they will be expensive though from what i hear....
it all depends on your cpu max stable fsb really....once you establish that then we can discuss whats gonna suit you best![]()
