Wondering if i've got a dodgy memory controller is going down the swanny
First off I have got Dubz Foxconn which his had to 279MHz FSB but i'm struggling to break 220MHz. I was playing last night on my Biostar and was getting lots of cold and warm boot issues at anything other than 200MHz FSB. I am also experiencing problems on the Foxconn.
I have tried 200Mhz with a 250 divider so memories at 250MHz but getting BSODs and warm boot issues.
I was getting memory errors in memtest last night at 250Mhz at 3-4-4-8 1T. I have also tried running various dividers etc unsuccesfully.
the CPUs was capable of 300*9 in my shuttle but the clocks have been gradually getting less and less
it was never run with a lot of voltage either usually a small bump.
I have tried all sorts of combinations and none seem to work. I have ruled out memory becuase this is new memory and tried running it on a 100 Divider.
Think I will need to get another CPU to test but from where I don't know....
Gonna prime it at stock and memtest it to see if throws any errors.
PSU is an Enermax Liberty 500w which is running 3.32v, 5.03v and 12.18v under load (DMM readings).
Tried switching multi to 5x and 230 and its hanging on boot. I have even tried running a 2:1 divider at 230 to rule memory out and same result
What are peoples thoughts?
