RickPlaysWarr
Hi
Looking into using Mayhem's glass tubing for my redo of the H440 Redux build. Has anyone used it? It looks pretty amazing and clear and should be durable and have no interaction with any fluid. I am torn as I realize that its going to be super expensive in fittings. Thinking of 16mm tube for the build. Just one 90 degree bend is going to be 2xBitspower 16mm Enhanced fittings and one 90 degree adapter. Thats close to $30 in fittings.
Do you guys think the glass tubing is worth it?
--Rick--
--Rick--
