Max Overclock for 6950 unlocked to 6970
adidube
As posted in my earlier thread, I recently bought a 6950 (MSI reference design) & unlocked the card to a 6970. Initially, I had a lot of issues with heat as the card was touching mid 90 degrees under load (read Dirt 2 & BFBC2), though benchmarking in 3d11 & vantage was not a problem.
A solution I found was the MSI afterburner utility wherein you can set the fan profile according to your requirements. After tinkering with the settings, I was able to reach a satisfactory result & now the card doesn't even come close to 90 degrees. So a highly recommended solution for those suffering from heat issues in the new 6900 series cards.
I have one more question. How far can I take the 6950? I did manage to run the card at 935 Mhz core & 1400 Mem with decent temps. All benchmarks were easy, but Unigine Heaven kept crashing. I wanted to know how far have you guys pushed your 6950 & how can I get the card to run heaven at 935-940? Also, is there a way I can unlock voltage tweaking through afterburner?
heaven is a benchmark that i need to reduce my clocks for too, they can be fine in every other bench and play games for hours on end but will crash in unigine
rest idk sorry
