ciobanulx
Hi guys,
Here's most of the piping done!
One issue I had with this is that two of the pass through fittings were way too close to each other and I only had Bitspower C47 style fittings that were a bit too large. So I ended up hand filing them down.
This was the result:
Just shaved off a few mm and they fit perfectly with a bit of tubing between them.
They're the ones at the very bottom.
Mounted the RGB LED controller for the Corsair fans in the front as well. This will be accessible from the side even with the front panel on.
And here's a look at the cable management.
And now the inside.
The red chrome tubes, with the fittings in the middle is a reference to the dual lightsaber.
Thanks for checking it out and stay tuned for more!
Cheers,
Alex
And now the inside.
Cheers,
Alex
