Matching screws as come with corsair h100i
Donkidonki
I have just treated my pc to a few new bits, including a corsair h100i.
To my pleasant surprise, the radiator will fit in the top of my cm690ii case in full push/pull config which I didnt think would.
I am struggling to find a supplier for black imperial screws to match the ones that came with the rad, I could use plain screws it would just look better in black.
Does anyone have 8 spare (6 32 1-1/4") or know where can get some in small quantities? I found one supplier but they only sell them by the 10k!
Any help getting all these lovely silent sp120's mounted up will be much appreciated.
Cheers
Managed to find some at www.specialtech.co.uk, and I don't have to buy them by the thousand:)
welcome to the OC3D forums,
check to see if you have a hobby store locally. dealing in radio control ideally. they
usually need smallish hardware as you seek and pre-packaged for convenience.
plus they can get stylish as well with torx, socket or slotted button head screws.
