Masterkleer Clear Tubing "genuine?"
Ghost_X
Hi there.
I recently ordered MasterKleer Clear 1/2 3/8 tubing and I am not sure if what I received is actual MasterKleer tubing. I have used MasterKleer tubes before and the one I received this time was very strange but I have never used this particular tubing before so I thought I might as well ask.
Firstly it feels much worse quality than the hose I used before. It is much stiffer and the walls are thicker.
Also the walls have a weird ice-like texture to them. Best picture I could get. Its quite tricky to take a picture of something transparent.
At first I thought it was because it was cold outside so the tubing was also cold when I opened it. But after a while the stiffness remained and I noticed the tubing also had a much thicker wall. I have shown this in comparison to an old piece of white MasterKleer tubing.
I ordered this from candccentral which is where I order most of my water cooling "fitting/hose/extras" so I consider them a trusted seller.
Many thanks on any input!
Just checked some Masterkleer i have laying around. (1/2in.ID, 3/4in.OD, 1/8in.wall thikness)
Regarding wall thikness its the same as yours.
It sure is alot stiffer, i came from tygon to Masterkleer and i first was shocked about it.
The ice-like texture is not present on my tubingg tho, mine is nice and smooth.
Maybe you got a batch that had some manufacturing issues.
Thanks for your reply.
I sent an email to candccentral and this was the main part of the reply I got.
Candccentral said:
[FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif]Looks like that other hose is the uv white ver[FONT=Times New Roman, Times, serif]sion? I[FONT=Times New Roman, Times, serif]f so[FONT=Times New Roman, Times, serif] [FONT=Times New Roman, Times, serif]we have also found it[FONT=Times New Roman, Times, serif] to have [FONT=Times New Roman, Times, serif]to be a totally different hose. Muc[FONT=Times New Roman, Times, serif]h more flexible[FONT=Times New Roman, Times, serif], thinner walls for some reason. We actually stopped selling it because we had complaints[FONT=Times New Roman, Times, serif] about it kinking too easily.[/FONT][/FONT]
[FONT=Times New Roman, Times, serif]S[FONT=Times New Roman, Times, serif]mall [FONT=Times New Roman, Times, serif]i[/FONT][/FONT]mperfections [FONT=Times New Roman, Times, serif]in [FONT=Times New Roman, Times, serif]this type of hose is pretty normal[FONT=Times New Roman, Times, serif], clear is probably the worse offender[FONT=Times New Roman, Times, serif] overall. [FONT=Times New Roman, Times, serif]I will get the stock checked, I wouldn't expect it to be that bad though.[/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT]
[FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif][FONT=Times New Roman, Times, serif]
[/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT]Looks like this is a known occurrence. Hopefully I can get a replacement.
