Master_G's Setup (56k WARNING!!!)
Haha, you're right phil, took me several attempts to get the right shot of the rad in the top, it's quite difficult to fit your head inside a full case to see where you are aiming the camera :p I found it is easiest to lie on the floor and look up rather than stand on your head though ;)
As you have probably seen me say before Kenny, i'd be rocking a bit more with my LS if i had a different motherboard, this one im stuck @ 2700MHz with this Newcastle 3500+, cant run dual channel and the voltages fluctuate too much. Was going to upgrade to Grouper over Xmas, but with the RD580 just around the corner i will probably wait until those boards come out so i have SATA2 etc as well as some more mature BIOSes.
Only problem is they are likely to come out just as i go back to uni, so not much tweaking possible over the Xmas holiday :(
Quite tempted to go for it anyway cos im itching for some hardware tweaking fun.
Thanks for the comments guys :)
G
hehe
Always the option of adding a cascade later :D
Seriously tho, that's a really nice looking setup G, you done good. :)
Cheers
Gray
Some day when i have either more skills in refridgeration, or more money (or both) :D
Thanks for the comments Gray, Jaffa and Shane. :)
G
