Do you know the moment when you just want more and more bass, but there are a few extra noises around? For example, your keyboard. In my case, the spacebar is the loudest creature moaning every time I do something involving lots of bass. And no, I won't turn it down.
This video will quite show what I mean : https://www.youtube.com/watch?v=Qljp_8eeMNk&feature=youtu.be
Turn your bass to zero and the volume up a bit.
It might not sound loud, but it is. It can sometimes be heard from the living room.
Does anyone know a simple fix to this problem which I should have realized already? I don't really want any "Well you can just pick up some weapon-grade uranium from the nearest kwik e mart thousands of miles away" but something small to put under the spacebar, spring or keyboard. I don't know, do you?
