Make AMD or i7??
Sh0rtS1ght
I am planning a gaming rig build real soon here are the specs buut would like to know your thoughts.
(Amd Build)
MB: Gigabyte GA-990FXA-UD5 (ATX Mboard)
Pro: AMD Phenom II X6 1100T BE 3.3 GHz (possible overclock 4Ghz)
Ram: 16GB (4x4GB) DDR3 1600Mhz
1TB HDD
128 SSD (possible extra)
Gfx: 2x ATI/Asus HD 6870's
700w PSU (possibly Coolermaster or Artic power)
help me here with suggestions (black)
the intel build is really the same buut using Z68 UD5 Board and a i7 2600k Chip, I am also possibly looking at getting a decent SSD, possibly either water/gel cooling depending on price
Any Ideas on what you might Add/change??
Looks good.
But you should better go with a single 6970.
Edit : I saw you added i7 as a possibility, so definitely go with Intel! 2600k is just way more powerful than any am3 chip to the date, and you should take a look at GTX470.
(Amd Build)
MB: Gigabyte GA-990FXA-UD5 (ATX Mboard) decent board
Pro: AMD Phenom II X6 1100T BE 3.3 GHz (possible overclock 4Ghz) can do 4GHz np but not with the 700watt CM psu
Ram: 16GB (4x4GB) DDR3 1600Mhz to much for gaming but if ya go this way in hopes of going AM4 then quad is in
1TB HDD
128 SSD (possible extra) to big if all ur going to do is put os on it even 60 is overkill
Gfx: 2x ATI/Asus HD 6870's I dont like AMD cards so gonna say 560Ti at least but would go 570
700w PSU (possibly Coolermaster or Artic power) this is where I'd chage I'd go with at min a 750watter if not 850 for xfire/sli and defo not CM
the intel build is really the same buut using Z68 UD5 Board and a i7 2600k Chip, I am also possibly looking at getting a decent SSD, possibly either water/gel cooling depending on price this is where its at for now bang for buck performance 2600k is overkill for gaming but I cant fault ya there as its what I'm doing get some good tight timing high speed ram and ur set
put my thoughts into ur post
For nearly the same money,i would get corsair tx 750 v2 psu.
8gb ram should do it.
And save up some money, buy a cheap p2 550 dual-core,and buy a bulldozer cpu when you can afford it,if you want to go the amd route.
For gaming,i would chose intel i5-2500k,asus p67 sabertooth,gskill ripjawsX http://www.gskill.co...s.php?index=357 ,msi gtx570 twin frozr III.
Important also,get noctua nh-d14 also
