[font=verdana, arial, helvetica]Hi, I've got a problem with my MachIIst. I posted about it on 2 forums, but nobody helped me, so I was recommended to post here
Here is the short version:
The compressor keeps turning itself on and off, every 2 seconds. But this only when the PC is turned off (even if I've just plugged the MachII into the wall outlet). I also get 2 error codes from the light diodes:
[/font][font=verdana, arial, helvetica]5 - Fail Sensor (when the compressor is just off)
6 - No Shut Down (when the compressor is on, as well as when the PC is working)
I *thought* the problem might be in one of the sensors, and specifically the one, which is tied to the condenser - the sensor is white, with this marking on it: "BRL2D 100C" (click to see a description of the sensor). It is connected with the chipcontrol via a white wire, and the connector is on the right side of the PCB, just on the opposite side of the On/Off connector.
When I disconnect this sensor, the compressor stops working and doesn't turn itself on and off anymore, so I thought this sensor might be faulty. If it doesn't open at 100C anymore, but rather at a much lower temp, that could explain the constant turning on and off...
If anyone of you can help me, please read the whole explanation as well, it might help you figure out the problem
So, here's the loooong version:
[/font][font=verdana, arial, helvetica]The MachIIst worked fine for about 3 months... until now.
A couple of days ago it was all fine, and then I turned the PC off and went to sleep. A strange noise woke me up 2 hours later - the compressor keep turning itself on and off - exactly every two seconds. But the PC was off. Knowing how deep I sleep, I suppose it could have been running for more than an hour, without me waking up (the PC is near my head, but then again... I sleep like dead)... it could have also just started turning itself on and off, I can't tell.
So I removed the Mach II plug from the wall and left it so for about 3-4 hours. After that, I plugged it again, but didn't turn on the PC. After about 2 minutes (like the cooldown time after turning off the PC), the compressor started turning itself on and off again. In the Mach II manual the error codes of the unit are only displayed as a decimal numbers from 0 to 7, but it isn't very clear which diode is the 0 bit, and which is the 2 (I'd assume that the first yellow diode after the red is the 0, and the green diode is the 2, but it could be just the opposite).
When the compressor starts turning itself on and off, the diodes keep blinking in the following way:
And this keep switching... over and over...
So, when the compressor is off, the code is 5 (fail sensor) regardless of the way the code is read.
When the compressor is on, the code is 6 (No Shut Down)...
Also, the power button on the PC isn't working - I tried short-circuiting the connector on the chip-control, but still no dice. Normally, when I hold the power button for more than 4 seconds, the Mach II will power down, and immediately send a power down signal to the mobo, which in turn will power down (after a couple of seconds, when Windows has unloaded itself). But now nothing happens, neither by holding the power button for even 10 seconds, nor by directly short-circuiting the connector on the chip-control. I also tried to disconnect the wires from the power button, in case it was damaged, but to no effect.
I tried something else - I jump-started the PC by short-circuiting the other connector from the chip-control (next to the one for the power button), and when the PC starts, the compressor stops turning on and off, and runs normally (but the above error code is still shown - the two yellow diodes light, the red blinks and the green is off). The PC works normally, and the Mach II is cooling *almost* as before, even though the error code is shown.
By *almost* I mean that the CPU temperature is now 2-3 degrees Celsius higher than before. I think that if some sensor is really faulty, the chip-control might be receiving wrong data, and run the Mach fans at lowest speed.
I also noticed, that when I unplug the connector on the chip control, which is marked as "THERMO" or something like that (it is the one with two white wires, and is connected to a bimetal switch on the condenser), the compressor stops turning on and off, and remains always off, but the fans still work, and rotate at the slowest speed as far as I can tell. This is with the PC turned off, of course. As soon as I plug that white connector back in, the show starts again...
What do you think is the problem? If this switch is faulty, could the chip control behave that way, turning itself on and off? Why does it start doing so, just after plugging the Mach II in the wall outlet anyway? Any ideas?
EDIT: The red diode is blinking all the time, all other diodes are not blinking.[/font]
Code:
[size=3]RED YELLOW YELLOW GREEN
On On Off On
(this is when the compressor is off)
On On On Off
(this is 2 seconds later, when the compressor is on)[/size]
