Mach 2 ST??? GT????
Re12
Hello then here, I have to buy a Mach 2 St, and I saw on the chart of control which there was a port USB as on the GT... I said myself that one can be could connect it in USB, I did it but Ca does not have to go, is what you know if one can the controller by PC? thank you
Hi there RE12 - not every ST can be modified via the USB soft mod I'm afraid - if that's what you're getting at. It looks as if you have one of the later models which doesnt mod :( The only way round it is to buy a Mach II or GT or work out how to replace the controller. Good luck!
ok, and if not is it possible to put the lcd? I have the catch for, it will post the temperatures? thank you
The only way to hook the LCD up to your unit is to buy a regular MkII (not the ST). Or swap your controller for a regular MkII's controller. The ST you have won't have the necessary driver circuitry to run the LCD.
So, on both the USB query and the LCD query, the answer I'm afraid is no.
