Hi All,
I am having problems with my mach2 gt.
I installed the mach 2 as per instructions from the manual but i am still having problem with what i think is a contact issue.
Basically startup the system and it boots at -66 mach2 software says -33, and when it is running in windows it reaches only -20 at idle, then if play a game for example it shoots up 56c and this happened just last night.
Also i remounted the head twice last night first time the cpu reached -9 then the second time -20 but still the same issue temp rose into the + temps and not staiging in the - temp ranges.
Could it be not getting proper contact i.e. flat on the cpu ?
Should i cut of the standoffs on the top plastic bracket to get better contact.
It is currently puzzling me that it goes up into the + temps and not in the - temps.
1 x Ceramic Stuff ( Mach 2 Head )
1 x P4 3.2 Ghz EE
1 x Asus P4C800-E Deluxe
Please help
1 x P4 3.2 Ghz EE
Please help
