Michaeljcox24
I'm about 3/4 of the way done now. Still got to put braided cable in and LED lighting for the block / res. Yes, I know tubing isn't very tidy by TTL standards but for me, as long as it doesn't leak, I'm ok with it for my first ever loop.
Been leak testing the past 6 hours with no PSU in the rig and everything seems fine. Just ran a bench on Heaven, and temps have dropped from 85C with the gainward coolers on, to 55C under water.
Had a couple of disasters along the way. The Alphacool L bend at the bottom leaked because I hadn't tightened it up enough. Had to dry the PSU out in the airing cupboard. When I re connected everything up after draining, I forgot to put the plug in the drainage port, and it pi**ed all over the desk when I was filling the res.
Still, it's my first ever loop, and you learn from these things. The first 12 hours you're on tenderhooks but once you get a feel that everything is water tight, it's immense they how quiet these w/c rigs are.
