Looking to install a sound card onto my desktop pc
truongvu221
Hello my question is what sound card should I get for my desktop pc and to let you know I really like to watch a lot of movies, listen to music and also I'm not an audiophile so if there's a sound card or program that can teach me that sort of thing it would be much appreciated price is no concern so anything is fine thanks and have a great day
What motherboard do you have?
Also, if they are the cheap logitech speakers I think you're talking about. Don't even bother wasting money on an expensive sound card..
I have the EVGA X79 Classified and also I'm going to get the Corsair SP2500 Speakers
Then nothing but the STX and STX II should be on your list. Only ones that will be able to drive them. STX 2 will be a better option if audio is a very big concern. Would be worth the money. Then again its probably not a better option since you are only getting the SP2500s which means you aren't that serious about it otherwise studio grade monitors would be on your list:p
