Looking to buy Backplate of a computer
Maxx
Hello im looking for somewhere to buy a whole backplate of a computer, for example the rear side of a computer case with the gpu slots,psu slot and iso slot. any ideas?
Cheers
Max
You'll be looking at buying an entire motherboard tray then mate.
Lian Li do a few:
http://www.lian-li.com/en/dt_portfolio/d8000-3/
http://www.frozencpu.com/cat/l3/g43...-Misc_Case_Parts-Motherboard_Trays-Page1.html
Or if you're based in the UK:
ATX
http://www.kustompcs.co.uk/acatalog/info_2041.html
mATX
http://www.kustompcs.co.uk/acatalog/info_2014.html
You could also have a look at some combinations from Mountain Mods:
http://www.mountainmods.com/motherboard-parts-c-21_34_66.html
Like this:
http://www.mountainmods.com/modular...-p-548.html?osCsid=olfhi6963i2vp1qrqpgkrvdhk3
http://www.mountainmods.com/mountai...-p-486.html?osCsid=olfhi6963i2vp1qrqpgkrvdhk3
Aaaaanyway, now you know exactly what you're looking for you should be able to find where to buy it yourself. They're pretty easy to find :)
Thats exactly what i would need. thanks alot bro i new what i wanted but i wasnt sure what it was called! niceone mate
for sure. it wont be for a while untill i get settled into my new flat. but im planning on making some nice stuff ;) gunna keep it secret for abit ;) xD
A cheap way to get one is buy a cheap-ass case from ebay and cut it out! Make sure you get one with enough slots for your project.
yea good idea also, was thinking of maybe just buying the motherboard cut out bit and gpu slots ect then buying a small sheet of metal and drilling the holes myself ect :D
