Hi.
Im new to the forum and found it after finding Tom's channel on YouTube. Im going to uni in 8 days and I have been wanting to build my own rig for a long time but due to lack of funds I have never been able to afford it.
Anyway, hardware wise I plan on grabbing the parts from a refurbed XPS 8300 simply due to cost, looking at the price of the system buying the parts on their own would be more expensive and it means I can spend more money on water cooling etc.
I then plan on getting the SilverStone TJ07 case which I will be getting powder-coated hopefully. Does anyone know if the whole front is made of Aluminum including the bay covers?
Now for the water cooling stuff. All I know is what I have seen in Toms videos and some other bits and pieces I have read online. Im guessing the best place to put the Rad would be at the bottom where the HDD's normally are which can be relocated to behind the drive bays with a tubular reservoir upright next to the motherboard and a pump somewhere below the res. Ideally I want to cool but the CPU and GPU. Until I actually buy the computer I won't know exactly what graphics it will have but I will certainly be getting an Intel i7 CPU.
I would really appreciate it if people could suggest some water cooling stuff that will fit in the TJ07 and be capable to cool the CPU and graphics. Also despite not being available yet, I really want to use Mayhems Aurora liquid so from what I have read of his posts it would be better to get parts known to work well with the liquid. As far as cost is concerned im not too fussed about cost but with about £800 going on the hardware, another £200ish for the TJ07 then maybe another £100 or so for Powder-coating so ideally I wouldn't want to spend any more than about £300 on cooling so I can then spend another £100 on other small mods and lighting.
Thanks for any help you can give me
