Look what I just had delivered
AceModder
Just had a delivery of the Antec P50 case.
I could talk about it, or just show you the images :)
The P50 is the latest addition to the award-winning Performance Series from Antec. The sleek exterior perfectly hides a large interior featuring room for 2 SSDs, 3 HDDs, a standard optical drive, and dual 240mm Liquid Cooling Radiators. The advanced cable routing and 8 fan mounts insure your system will stay at optimum temperatures under any situation. Silence is always a
focus for the Performance Series, as High Density Polycarbonate (PC) layers on inside panels keep the fan noise and system vibration to a minimum, making the P50 a perfect solution for small-format home theater, media center, conventional PC, and gaming rigs.
SPECIFICATIONS:
• 6 drive bays:
- 1 x 5.25" Drive bay (removable )
- 3 x 3.5" HDD
- 2 x 2.5" SSD
• 4 x Expansion Slots
• Motherboards: microATX, Mini-ITX
• Maximum graphics card size: up to 300 mm (11.81”)
• Maximum CPU cooler height: up to 130 mm
• Cable Management: Cable routing space behind
motherboard + Cable routing holes
• Cooling System:
- 2 x 120 mm + 1 x 80mm front intake fans (included)
- 2 x 80mm mm rear fan (optional) + 1 x 80mm (included)
- 2 x 120 mm top exhaust fans (optional)
- Capable of mounting a 240mm radiator for water cooling in the front
- Capable of mounting a 240mm radiator for water cooling up top
• Top I/O ports:
- 2 x USB 3.0
- 2 x USB 2.0
- 2 x Fan control (High/off / Low)
- Audio In/Out
• Front I/O ports:
- 2 x USB 3.0 with internal motherboard connector
• No power supply included
• Unit Dimensions
- 500 mm (H) x200 mm (W) x 450 mm (D)
- 19.7“ (H) x 7.9 " (W) x 17.7"(D)
• Package Dimensions
- 532 mm (H) x 269 mm (W) x 575 mm (D)
- 20.9” (H) x 10.6” (W) x 22.6” (D)
• Net Weight: 13.8 lb (6.26 kg)
• Gross Weight: 17.2 lb (7.82 kg)
Its got some neatish features. Its a shame that it doesn't look more p380 as I really like the way that case looks.
