Logitech Harmony 525 with XP MCE ?
FalconFX
Hey there...
simple question this time :D
Is the Logitech Harmony 525 compatible with XP MCE 2005 ? Couldnt find an answer.
by the way... nice new forum style
FalconFX said:
Hey there...
from what i see, it's just a universal remote, you will need a receiver for the actual pc. universal remote's are almost always programmable, so im sure you could get it to work if you could find a receiver that works with both mce and the remote.
hope this helps.
EDIT: ok, read a little more into it. that control isnt "pre-programmed" for mce. But go to the following link to see which other are. http://www.logitech.com/index.cfm/products/features/harmony/FI/EN,CRID=2078
Holy crap!!! That's a sweet looking remote...apparently a little fiddly to get used to, but sexy as :worship: . I've looked at some reviews for it, and couldn't find out whether it was compatable with XP MCE 2005, but as nabberuk said "it's a universal remote, it should be able to be programmed for it"
