Lian Li PC-B25F possible for future watercooling?
Runebeard
I really like the PC-B25F as I wanted a mid tower for slight portability as and when required, and I've seen in reviews it has awesome temps even when air cooled. I also looked at the Lancool K62 which follows a VERY similar design shape, but I can't seem to find any cooling temps and it's also made of steel which makes it slightly less portable though probably more durable(?). The clean lines of these types of cases is what attracts me, not a fan of 'gamer' cases with lots of sticky-outy bits (even though I'm a gamer myself). The all-tooless design is also a winner.
What I want to know is do people think that if I wanted to make it watercooled in the future would it be possible? I haven't actually seen one in the flesh but from photos I've seen there appears to be limited room in the roof for a radiator so I was thinking something like a Black Ice GT Stealth would probably have to be used plus a small rad for the rear exit fan?
It's probably pretty obvious I have little idea about watercooling, so I thought I'd get some expert opinions on the possibilities. And Feel free to critique my choice of cases and suggest possible alternatives, not relly looking to spend more than £130 on a good quality case.
Cheers peeps.
The B25F doesnt really lend itself to an easy modding or instalation of water tbh. What are you looking to cool in the loop so I can get an idea how much radiator real estate we need to find a home for.
I'd probably be looking at just CPU and single GPU and not the motherboard as I was hoping to be able to find a Mid Tower to fit it in.
If you think it's probably easier, I'd be fine with going for a full tower as long as it's not the Corsair Obsidian 800D - my mates got one and breaks his back everytime he moves it lol.
Cheers for the advice Tom.
