LED Strips
MadShadow
So I'm looking for some white LED strips to light up my new build, but I have no idea what is good and what isn't. So what LED strips do you use? Thanks guys ;)
sorry if this is the wrong place to post
I think you probably could although don't quote me on that as I have not used them without it
the expansion slot thingy lets you switch them on and off and has 3 different brightness settings :) but im sure there is a way around it as it comes with a molex to 2 pin
Phobya FlexLights (available under other brands) are pretty good. The high density versions are insanely bright though. Best thing is to wire them on a fan header and drop the voltage as needed. You can get them from aquatuning.
Darkside have some really nice LED's too which you can buy from Mayhems store. I've got some but yet to test them in a rig. From what i've seen in other project logs they look outstanding.
JR
I can recommend the IceModz LED strips. You can get them in different lengths, colours/rgb, with remotes, etc. Drop them a mail with what you are looking for and I'm sure they'll help you out with exactly what you need. I'm using these in my rig and I'm very pleased with them
Interesting one, Ill have a look at them as well! Cheers
