{TTG}Scarecrow
hi im doing my first major cooling upgrade from air to water my case can be seen in the air gallery project pc71 Green glow. but i decided temps of 55 degrees were too high from jet 7 blowers and 6 case fans so i decided to go wc the main reason was i couldnt justify spending £600 on a Mach II for me thats a whole months wages so water cooling filled the hole.
with a little help form a friend of mine (Boardy cheers mate) we knocked up a shopping list of wc parts to get with a price range of aproximatly £300 here is what i got:
Eheim 1250 pump
Danger Den (DD) RBX 1\2" CPU COOLER
DD Maze 4 Chipset cooler
DD Maze 4 GPU cooler in Green obviously
Thermo Chill HE120.2 RAD
1/2" tygon tubing
2 panflow 120mm fans
plus all the other gubbins that you get barbs connectors and a S#*T load of clips for each connection
i plan to connect everything up in a week or so cause im away on holiday but my only fear is having to cut a hole in the top of my lovely case that and how to fix the rad in place up there, while still keeping it looking neat.
suggestions are welcome
Eheim 1250 pump
1/2" tygon tubing
