Latency update help!
LiamTheBoss
Hi there,
A while back I posted on this situation which I am having which is high DPC latency causing games to stutter. Using latencymon the culprit is usually directx or nvidia drivers. I disabled GTX 670 in device manager and the latency completely goes.
Does anyone know where I can go from here?
Any help would be much appreciated.
The first thing I would try is completely uninstalling the current nVidia driver.
IE:
*Uninstall the current driver.
*Reboot
*Run a Registry Cleaner like CCleaner
*Run Driversweeper to get rid of any "Leftovers" from the driver
*Reboot and re-install the latest nVidia driver from their website.
Updating your BIOS to the latest version is worth a shot too. I found a DPC latency problem on my old laptop was fixed via a BIOS update for instance.
What's the motherboard?
