I finished up a bit of a lineset for Fragtek a while back, shame he probably wont be using it. Otherwise just wanted to a show a bit of work. I purged with propane during this... "ordeal" of evap building. And its abusively big, but works quite well.
.5" cap, then 1" 1.5" and 2" with a 3" x 3" copper base with holes drilled half way thru it under the caps for surface area. The plate is 1/4" thick and this sucker is heavvvyyyyy.
Capillary is 115" of .028 and suction is a flex line from drewmeister which is quite long (40" or so).
I'm going to cut down the base plate a little more, probably make an octagon out of it but cutting copper with only a hacksaw is a pain in the keister.
Comments and such..
Also, I know the cap size is rather huge, next time probably .5", 1", 1.5" and be done with it. Eh whatever. The caps are also damn expensive where I am, so if any of you know where to get cheap caps up to 2" or so please shoot me a PM.
Comments and such..
