Laptop- Wrong Memory Frequency
MadShadow
So I replaced the default 6 GB ram kit on my ASUS N56VZ with Corsair CMSO16GX3M2A1333C9 Value Select (2 x 8). For some reason, the ram decides to run at 666 MHz, while it should run at 1333 MHz. I dont know where exactly I can change this on this laptop, so does anyone know how?
Cpu-Z screenshot:
EDIT: never mind, SeekaX helped me out
Double 666 and you get 1333, it's double data rate memory so you double that number cpu-z gives you to get the actually speed. I have 2400 Mhz memory but cpu-z said's 1200 Mhz. Hope this explains it :)
