laptop help
syfer1987
Member
Hi you see my laptop in repair at local high street brand and if they can't fix it which they have yet to do they told me I would get a voucher for the same price as my laptop so just in case I locked at some new laptops and they are
HP ENVY x360 14" AMD Ryzen 7 2 in 1 Laptop - 512 GB SSD, Black
AMD Ryzen 7 3700U Processor
- AMD Ryzen 7 3700U Processor
- Quad-core
- 2.3 GHz / 4.0 GHz
- 6 MB cache
16 GB DDR4
Graphics card AMD Radeon RX Vega
Storage 512 GB SSD
£999.00
LENOVO YOGA 730-15IWL 15.6" Intel® Core™ i7 2 in 1 - 256 GB SSD, Grey
Intel® Core™ i7-8565U Processor
- Quad-core
- 1.8 GHz / 4.5 GHz
- 8 MB cache
RAM 16 GB DDR4 (2400 MHz)
Graphics card - NVIDIA GeForce GTX 1050
- 4 GB GDDR5
Storage 256 GB SSD
£1,099.00
HP ENVY x360 15.6" Intel® Core™ i7 2 in 1 - 512 GB SSD, Silver
- Intel® Core™ i7-8565 Processor
- Quad-core
- 1.8 GHz / 4.6 GHz
- 8 MB cache
RAM 16 GB DDR4
Graphics card - NVIDIA GeForce MX250
- 4 GB GDDR5
Storage 512 GB SSD
£1,299.00
Can some tell me out of these three which is the best specs laptop?
I really don't know how the RX Vega compares, but out of the MX250 and GTX 1050, the 1050 is the better graphics card. My only worry with the Lenovo is whether or not you can upgrade the SSD. 256GB is pretty small.
What do you plan on using the laptop for? Is mobility above gaming performance? That AMD model you listed should be smaller because of the smaller screen.
MX250 is balls. If you want to game on the laptop don't buy that one.
I wouldn't buy anything made by Lenovo due to security and other issues they are plagued with, so that only leaves one.
https://www.youtube.com/watch?v=C_mGucf106w
That is how you apparently swap the hard drive.
In future man have some patience. The thing is, until I read this thread I was about as clued up as you were I just spent 2 minutes digging around on Google and Youtube and hey presto, all answered.
With my MSI laptop I had to remove everything from the case as the M.2 slot is on the other side of the motherboard. Total PITA. It's a great laptop otherwise. Not as solid as my MBP, there's definitely some flex to it, but the performance has been solid and the screen is great.
The Ryzen laptop has 512gb which should be ample really.
If not an external USB 3 SSD will hold games etc.
