I've been looking at Fan Controllers recently and spotted the one in the FS&W section...
I like the idea of the led display and was favouring it, and was looking at the kaze master pro ace as well as lamptron fc5v2 and fc6, which are all around the same pricepoint.
I don't think I'd make good use if temp sensors as I'm not OC MAD! so no biggy
Then there is the Lamptron FC2, which is dials only with blue behind the dials and for a little over £10 I can get one I black.
Is this a no brainer? or is there a design flaw or something with FC2?
thanks
Edit.......
Just found and now reading through the review on here from 2008
thanks
Edit.......
