My little project, just to prove that with a little effort, even smaller size cases can be tastefully (imho) watercooled-enjoy
Computer Components
Case- Coolermaster Haf 922
Power Supply - Coolermaster 700W Silent Pro
Motherboard - MSI Z68A-GD65 (G3)
Processor - i5 2500k
Graphics - EVGA GTX 460 FPB
Memory- Corsair XMS 3 2GB x 4
Storage - 4x noisy HDD (2 x Seagate 500GB & 2 x WD 500GB)
Watercooling Components
Reservoir - EK-Multioption RES X2 - 250 Advanced
Pump - Aquastream XT Ultra (got it for only 58 Eu BRAND NEW)
Waterblock - XSPC Raystorm
Radiator - XSPC EX240 w/ push/pull (push 12cm slimline Scythe slipstream 1200 rpm x 2-due to the case constrictions) (pull Scythe GT 1850 rpm x 2 mounted on top)-im still playing around/testing the use of push/pull-the jury is still out at the moment.
Tubing - Primochill LRT clear (10mm ID - 13mm OD)
Fittings - EK Black + 2 x 45 degrees Aquacomputer fittings
Fluid - Distilled Water + PT Nuke/silver kill coil
Loop Order
Reservoir -> Pump -> Radiator -> CPU ->Reservoir
Extras
Accelero Twin Turbo II gpu cooler-(its great with very low temps 45-50 under load & occed)
Kingston Ram cooler
Shoggy sandwich(pump anti vibration pad)
Lamptron fan controller FC5 V2
Coolermaster ' 4 in 3' (allows you to place 4 x hdd in 3 drive bay space-comes with 120 mm coolermaster blue led fan-imo i should have got the Lian Li one instead, but that point is moot now since ssds will be the way to go)
Things that ive lost
Skin off my knuckles (try working in such confined spaces lol) and ***** loads of patience at times
BEFORE
AFTER
UPDATE
Added:
2x EK-VGA Supreme HF Bridge Edition - Acetal-2nd one will be mounted when my 2nd card arrives
-ive also ordered 1x EK-FC Bridge DUAL Parallel 3-Slot
1x XSPC RX 120 Radiator
1x GT 1850 rpm
Changed clear Primochill clear lrt -> UV Blue Primochill lrt tubing (10/13mm)
Added 2 x Koolance Quick release fittings (2 x male/female) to enable easy removal of top radiator for cleaning.
Added 120cm Phobya High intensity UV led strip.
Added UV Blue 120 Gelid Wing as exhaust fan
Changed Sata 2 cables to Sata 3 cables-for the immanent arrival of new SSD drives.
8x Enzotech copper vrm heatsinks
2x 90 degree EK fittings (Black)
2x 45 degree EK fittings (Black)
2x Jon Lund Reservoir Lighting plugs-they are phenomenal, they make all the other ones out there look like........
Footnote: excuse the cables that are visible, i had to rush the photos
OPEN CASE-STOP THE PRESS-DOORSTOPS MAKE KICKA** CASE FEET!! Just kidding, they are a temporary solution till my MNPCTech Set of 4 Diamond Knurl Case Feet Black arrive
WITH CASE PANEL
WITH UV LIGHTS ON -Lights are controlled by spare channel in my fan controller-gives full control (see begining of post post for Fan Controller info)
EPILOGUE
At times i must admitt that i wanted to chuck it all in and get a larger case, but with some minor mods and bucket loads of patience, i was able to do mod my HAF 922-my only regret is buying my H80, aftermarket gpu cooler etc-basically i should have gone straight to water cooling instead of the 'pitstop' that i took. 'Ok Muttley, time to figure out how to get rid of the unused gear'
Computer Components
Loop Order
Extras
Kingston Ram cooler
BEFORE
AFTER
UPDATE
Added:
1x GT 1850 rpm
WITH CASE PANEL
EPILOGUE
