Certain modifications will be needed to support the higher thermal requirements.
All thermal pads will be replaced by either 0.5mm phobya or phobya XT pads, the thermal paste will be replaced with IC diamond and depending on temps I may cut vent holes into the cover. There are also a couple of other tricks I intend to try.
you want to build laptop and you are aiming for nearly 5GHz? good luck, that thing will be hot as hell. also i am not sure if a 240W PSU is gonna cut it.
