Well turns out its not perfect, infact the tip just melted its plastic sleve and shut off my system :/
Obviously not acceptable so I have looked at the unit and it can be opened (with the correct anti-tamper torx screwdriver (6 point star with a centre pin)) I have ordered a pre-fitted tip cable and will solder that straight into the main unit which should ensure good connection.
