Hiya guys
I've just got my prommy mach II GT (thanks to barkerd for selling it to me)
Anyway i've managed to get it up and running!! Using it to cool my 3400+ clawhammer. The mobo im using is a DFI NF3 UT Lanboy and i've installed the hardware monitor to see what my CPU temps are. It gives me 222°C so guessing i'll need a patch or some other kind of monitor. Anyone know of any to use??
In the bios though it says my temps on the CPU were -29°C on the Mach II it says its -63°C so am i getting good temps?? Just wondering if i have got good contact on the cpu.
Also bit of a bugger here.... the hose which goes to the cooler is sticking out just abit too much to close my lian li side pannel...Anyone know what i can do??
Also the USB wire from the Mach...I've looked at the wires and checked them with the mach II manual and the mobo manual and it appears the wires are all mixed up wrong. Should i just pull them out and swap them around or do i just plug it in and see if it works??
Sorry for all the newbi questions guys...Anyone on here with the same mobo/CPU as me would like to see how far you've managed to go!!
Hope to hear from some of you
Greg
Greg
