Feronix
Heya guys!
So the time has come that the PC in my signature will soon be gone. My mate is coming to pick her up on Monday, which means that I will finally have the cash to fund my ITX build.
Now, the build will feature a black & white colour scheme, and I want to toss in a couple of bright green accents. It will also run both W8.1 and OS X so a Gigabyte motherboard is a must (and that's also the reason I decided to go with 2x1Tb drives rather than one large drive).
This is my spec list as I have it right now. Anything you guys would change, or possibly hardware with similar performance that can be found for cheaper?
The reason I went with the Xeon is because of the Hyperthreading and the attractive pricing. I'm not much of an overclocker/gamer anyway and rig will mainly be used for productivity.
I already have a case (White Phenom ITX), some RAM (2x4GB Vengeance Low Profile white (thanks Etlar) and a white cable kit (with the exception of the 24 pin).
The ACX cooler will be painted and I want to make a backplate for it. It's also the only non-reference cooler with a closed shroud on the top and bottom and easiest to mod I think.
Going for the Spectre Pros as I want similar fans throughout the build and they're one of the few that do 230mm ones, also the fan housings are easy to remove for painting and from what I've heard they're alright fans.
Any thing you guys would strongly advice me against or just change in general? Let me know!
Thanks
Thanks
