GoLLuM4444
name='maverik-sg1' said:In 03 remember to hit delete
Do you mean esc or does delete work too?
maverik-sg1 said:Best I scored was 10500 with FX55 @ 3.5Ghz or X2 4800 @ 3.14Ghz - but that was before I managed to get more bandwidth from the GPU RAM.
That XT aint performing too bad at all is it - nice one.
Give it an 01 and 03 run as see what you score.
In 03 remember to hit delete when the CPU tests start (after nature) it cancels the rest of the test but will still give you a score (pro version on the cheap doing it that way).
name='maverik-sg1' said:In 03 remember to hit delete when the CPU tests start (after nature) it cancels the rest of the test but will still give you a score (pro version on the cheap doing it that way).
name='GoLLuM4444' said:Do you mean esc or does delete work too?
name='GoLLuM4444' said:9*** in 05 at 3.3Ghz cpu, stock gfx clocks.![]()
name='scorchio' said:Looking good nice tidy case by the way!
name='Animal' said:K sorted 01, now i get 33460....
maverik-sg1 said:JAFFA - 9000+ is a great score in 05 @ 3.3Ghz - I scored 10500 with voltmodded GTX and 3.5Ghz
What are your temps like (idle/load).
maverik-sg1 said:Clocks/Temps?
Great score to boot![]()
TEAM EPUK 4EVA!!
