Shawn22Moore
I have about another 1,000 dollars to spend on a upgrade for my current system.  I built it last year with the help of you good people.  My specs will be posted below. This paragraph so you can help me choose what to do.  So currently I am debating between a few different upgrading options.  My graphics card, My ram, or my processor.  If I were to upgrade my processor I would like to upgrade to a card that will destroy anything most likely the GTX 600 series.  Currently I have a GTX 560 2 GB I used to have a GTX 570 HD SC but sadly that card died on me I am still unsure how it did.  Anyways I could either go with another GTX 560 2gb in SLI, or attempt to sell that card(Perfectly fine card) and upgrade to a powerful single card.  With my ram I started out with 8 gb 1600 ddr3, and stepped up to 16 (4x8gb) and now it seems 1 or more RAM sticks have died on me,  (Currently running Memtest to determine what sticks).  If I were to upgrade I might do 16 gb or 32 I am not sure I multitask like crazy when I gamer and such.  Any ideas?  And this time I would like ram that WILL NOT die on me.  (I cannot return it either because they were gifts)  And lastly I have a AMD 1100t OCed at 4 ghz.  I think I will be fine with this processor for a while.  But my other parts do need tending to.  I would rather not spend all 1000 dollars.  and Just spend around 600-800.  OR LESS.  I do need to upgrade my home network and also buy a new nic card for my computer as it seems that died on me too.  Not a great experience but everything is still operational.  The ram issue is very frustrating as my PC crashes frequently, and with games coming out now a days my Graphics card isn't handling them as well anymore.  Try to comment ASAP.  Thank you.
Case: COOLER MASTER HAF 932 Advanced
Motherboard: ASUS Crosshair V Formula 990FX
Graphics Card: GTX 560 2 GB
Power Supply: CORSAIR Enthusiast Series TX750M 750W
Processor: AMD Phenom II X6 1100T Black Edition Thuban AM3, Six Cores Clocked at 3.3 ghz Turbo Speed up to 3.7ghz.
Overclocked to 4 GHZ on all 6 cores.
Boot SSD: Crucial M4 CT064M4SSD2 2.5" 64GB SSD
RAM: G.SKILL Ripjaws X Series 16GB (4 x 8GB )DDR3 1600
Storage HDD: Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM
Western Digital Green 2tb
DVD Drive: ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner
CPU Cooler: Noctua NH-D14 120mm & 140mm SSO CPU Cooler
-Shawn
-Shawn
