Is this normal?
stevej696
Hi people I have got an Antec300 case with 4 120mm fans installed all running 1400rpm and a Asaka AK965 cooler cooling my chip currently running at 800Rpm. With our cold spell around i thought it would be the best time for a temp session so my room temp was around 10*c. Its currently running at 1.80GHz with the Eist running too and i was wondering if this is the possibly the lowest idle temp for a air cooled computer? Bearing in mind this is with the Eist currently lowering my multiplier.
Is this a good result would you say?
:oc3d:
I've seen lower, but it's pretty good. The lower ones where were people used air ducts to channel cold air from the outside directly into their cases. Not a pretty sight but it got them their low temps :D
