£1,092.77
I'd rather stick with the build I have chosen because you guys keep going over budget.
hehe waaay to easy to do im afraid. but it is up to you in the end, you must be happy withh your build
Is this better then?
CPU: i5-3570k
Motherboard: Gigabyte GA-Z77-DS3H
Memory: Corsair XMS3 8GB-1600Mhz
GPU: Asus GTX 770 Direct CU II OC
Case: Zalman Z5 ( I'll buy a better one when I have the money.. )
HDD: Kingston 60GB SSD ( I have HDD's from Prebuilt PC )
Optical Drive: LG LG GH24NS95.AUAA
PSU: Corsair CXM 600W
£795.48
I know that. But I'm only 16. I don't know where to get the extra money from.
CPU: i5-3570k
£795.48
please, forgive the pressure we created, as i suspect, we are used to pay atleast a bit extra just to get the more respected or proven brand, or newer product.
i see your priority is a great GPU, and overclocking capable CPU+MB, well there you have it, in fact you won't get much more out of your budget. even that SSD you can buy later, but if your old HDD is really old, consider it
And i think, unless you'll keep feeling some odd urge to upgrate things, you might even find yourself having a decend rig for couple years
My HDD's are pretty good and I'm gonna upgrade to a i7 when I have the money![]()
Hmm. May I suggest picking up an i7 now? Maybe get a great deal on a second hand one. Seems like a waste of money to buy the i5. Maybe save the money from the ssd. Buy the cpu you have want to end up with. And buy a ssd when you can afford
Just trying to help ya get the best computer,
And that is the very reason ya here.
Will you will be doing any rendering? As you're only 16 i suspect the most intense thing you will do is game and possibly render videos to youtube. The i5 would still be my suggestion for that. The rig you spec'd out looks good overall. I would drop to a lower and cooler and get a MLC ssd and not the TLC 840. the non-pro 840 is nothing great and dies faster than normal ssd drives.
