RaiderX303
27c idle and 51 load is not hot for 3.6GHz 1.575v, only chip i said run hot was my 6300
name='cuprasport' said:bah u aint even got the gtx so its well inferior to the d-tek fuzion![]()
name='Mr. Smith' said:fight fight fight!!!
name='cuprasport' said:no way is yours better than mine m8 look at your cheap loop with poor cpmponents
name='RaiderX303' said:if you get 7/16" tubing with 1/2" barbs, the plastic clips would be enough as the tube is quite tight over the barbs, looks better than jubilee clips
name='da2ca' said:I've read on a few forums that if you use the 7/16 its that tight ion the barb you don’t need any clips. Is this right?
name='cuprasport' said:yes, u need to heat the tubing up sometimes to get it on
