is this adequate HAHA
SparkleDJackson
took the cover off the pc in work today for giggles. this has to be the neatest custom pc ever lol. i cant believe my parents got some guy to build this. also its only got 2 fans lol a 60mm intake and a 120mm exhaust. ive never set up anything fan cooled before so im just going to presume that it aint much air being pumped through. ive never run any tests on it. i suppose is should considering its got cpuz and all that jazz on it already
from the pic it doesn't look to bad tbh ive seen allot worse cable management
most likely it will be fine with that number of fans, the psu will move some air too it most likely has a 120mm fan aswell. there will be plenty of air for the cpu and the gpu's exhaust ends up out of the case too so i don't think there much to worry about
any idea on what the spec is
Haha, well at least he tied the cables together, the builder should have just tucked the big wad of cables into the 5.25" bays and tucked the sata cables within the hdd bay.
its like 3 years old they got it when i was still in school so i had no say in it lol.
e8500 dual core (cpuz screen below fluxuation in clocks between 2ghz and 3.15ghz)
msi p45 neo
4gb kingston valueram
toughpower 850w
ati 4870 512mb edition
500gb hitachi deskstar
yea the clock bounces between those figures as if there is a turbo or something if im watching 1080 on youtube etc
seemingly the thing works well it runs just cause 2 at 1440*900 everything on high very very comfortably
heres the pic if that is wierd i dont know
msi p45 neo
toughpower 850w
its called speedstep
i would hazard a guess that if its been working ok for the 2 or so years since it was built that it is adequate yes. it could be better yes but it is doing the job needed.
