Trollgaard
So, have you all got your coolers fitted thightly?
I got myself a brand new high-end rig the other day. I built it in a few hours and let go. All seemed nice and smooth. Except for a missing boot...
Ok. What to do? I always start with the memory. Remove all the dimms except 1. After a bunch of tests I figured out that the DIMM_B1 didn't work. The BIOS also notified that OC failed when no BIOS changes was done. Not even XMP set. Tested all available BIOS updates without any difference also. So, I have returned the MB to get a new one.
However. When I dismantled the CPU cooler, I noticed that the thermal paste was not covering the whole cpu. There's always one thing you can be sure of when mounting your cooler; You will never know if you've used enough thermal paste until you take the cooler off again. For my part, I hate having to dismantle a cooler. When I first have it all in my case, I want to start gaming or overclocking or whatever right away. I had my i7 920 at a stable 35-40 C with my 4 gigs of ram, but I'll be damned if I'd have to look at my last 2GB lying on the desk. When I get my new MB I hope I'm gonna get the temp at the same level or lower. But here's the questions:
Did I use too little paste?
Is there a bump in the middle of my i7 that made the paste gather there instead of spreading out to cover it fully?
Has anyone tried lapping the i7?
Does anyone have any good explanation? I have to admit that I have never experienced that the paste haven't been pushed all the way to the edges. But then again, I haven't really thought about it at all except on my last 3 cpus which I assembled myself. I have always been sparse on the thermal paste, but didn't think I was too far off when assembling this one.
How do you guys do it? One dot in the middle or spread it out on the whole cpu?
