I have a few basic questions about watercooling, because I plan to WC my rig in a hopefully not to far away future, but atm I need to get a new case because of thermal issues with my current one. I plan to get a HAF X of coolermaster. I will replace the front and side fan with spectre pros, but using the 200mm one of the side in the top until I get WC.
When I watercool my future rig I will go either with a 45mm(alphacool) or 60mm(phobya) thick radiator. Here starts my 1st question: Would it be a option to place the phobya rad in the top with fans pulling air through the rad out the case? Moreover I wouldlike to know if there are serious performance issues compared to a push config?
Atm. I'm using an H60 which I'm going to keep until I get a real WC. Therefore I want to buy fans for it that I can use for my WC later on. My favourites for that position are atm two Noíseblocker BlackSilent Fans XLP-120mm PWM. Would they suit a pull config? Another question about the fans: I have got an fan control of phobya which is for 3-Pin fans. Can I use this for 4-Pin fans or would I need a adapter?
I really have to stop typing now. Hoping for some helpfull replies.
