Is my PSU going to cope now?
k4p84
Still building up the kit for my project.
I have a Zalman HP 850 PSU
Here is a quick run through of what is going into the PC:
Q9550
SLI'd GTX 280's
8 GB ram
Single watercooling loop
usual optical and HDD plus about 6 cold cathodes
I had planned on using 8800GTX's but i ended up getting this PSU prior to upping the GFX.
ED
the calculator gives me 750W, but i am planing on an OC of both my GFX's.
since the rule of thumb is max W your rig can draw should be 100w lower than PSU i think i may be pushing it.
what are people thoughts?
ED
Zalman PSU's cost a bomb. Which should indicate quality.
850w is plenty, and if the supply is good you will be fine.
I think these are the specs of this psu
''OEM: Enhance
ZM850-HP ~60A''
Im not familiar with Enhance but they seem to be ok.
I am very tempted to get a Enermax Galaxy 1000w so i can pop in another gtx 280 at a later date,
Hence the Zalman 850W been for sale :)
ED
